Old 12th August 2013, 04:20 PM
BenBrooks BenBrooks is offline
Default build wheels wanted
Hi all,
I'm after a very cheap set of 15/16in steel wheels with tyres so i can get my chassis on wheels if anyone has any? Preferably near surrey area so I can pick them up.
Ben
Build photos: http://s1056.photobucket.com/albums/t362/benbrooks1/
Old 12th August 2013, 06:36 PM
What donor are you using? If its an mx5 I've got 4 space savers that I used you can have for free as long as you arrange a courier
Old 12th August 2013, 06:48 PM
sorry, should have said in my first post, i'm sierra based. thanks for the offer though
Old 12th August 2013, 09:23 PM
jps jps is offline
it's it possible to get steel wheels that big? I thought they were all 13s?...
Old 14th August 2013, 09:08 PM
14" are OK too, my build wheels were that size. Sierra did come with 13" and 14" wheels.
Old 15th August 2013, 07:33 AM
i tried 14s on the rear and the long bolt on the bottom of the upright scrapes against the rim, even though i cut a bit off
Old 15th August 2013, 07:37 AM
Richard Dryden Richard Dryden is offline
Default re
If you put the rears on inside out just for the build smaller wheels will fit as it will avoid that long bolt. Have u tried local scrap yards?
Richard
Just keep going we will get there in the end.
Old 16th August 2013, 02:58 PM
my std ford sierra 14" steels fitted fine?
you need a bolt only just long enough and if 14" steels fit 15" alloys will only just fit!
Old 16th August 2013, 07:50 PM
okay cheers guys, i will try again but might try Richard's idea if they still won't fit.
Old 16th August 2013, 08:56 PM
I had to cut my bolts to 233 mm. This way there is one turn of the thread above the nylon. This way the wheel fits, but the clearance is minimal
