Old 24th August 2013, 10:09 AM
Default wiring loom head ache
I decided to pull the wiring loom from the mx5 yesterday afternoon after I've been telling myself all week that I was going to leave it alone, I've even written on the body work 'do not touch!'
I don't have more than half the things that plug in to any of the connectors which will make things interesting come refit time, my donor has no interior, doors or any of the dash. So today I'm stripping all the tape from the loom and separating the the engine and lighting from things that a Roadster does'nt need, such as the heavily butchered stereo wiring, aircon control (why would you want this in a rag top?) and any redundant connectors fitted as standard.
I feel a head ache is coming my way later on.....
Old 24th August 2013, 10:20 AM
The popup headlight motor control was the most annoying thing to remove for me.
The only thing I regret just stripping out it the dash dimmer. I know I'm going to have to track back and run a bypass to get my dash lights to come on which I'm sure would have been more obvious with the dimmer in place.
Once you have all the black tape off its fairly straight forward. You cannot wear gloved as you cannot grip the tape and it wont wash off your hands for about a week either!
If you look online madracki publish a free wiring diagram you can follow. If you cannot find it I will send you a link.
If you don't know what something is pop up a piccy and we can all play guess the part!
Old 24th August 2013, 10:59 AM
Ah pop up head lights,you have just enlightened me as to what goes in to the mystery plugs at the front. I think it's the dash plugs that will be the most fun.
Old 24th August 2013, 12:17 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
I got a couple of books for the mx5 I wont be needing for a while if you want them popping in the post for you to borrow the haynes one has the wiring diagram and the other just describes the plugs so together they make a good combination will just get them back when I pick up a chassis kit off you
Old 24th August 2013, 04:34 PM
Stot, the dash lamination wires are red, and white. If you can't find them behind the dash, why not use the old wires that went to the ash tray light on the arm rest console ?
Old 24th August 2013, 07:18 PM
You'll probably get confused over the lack of relays as well and where they are supposed to be.. I know I did..
I found it somewhat confusing following wiring diagrams for cars destined for use across the pond and then modified for UK use...
I ended up with only 3 individual relays which confused the hell out of me at times.
