Old 3rd September 2013, 10:40 AM
MikeB MikeB is offline
Default Dashboard blanks
Has anyone bought a dashboard blank that fit our roadsters? I using the AGM bodywork but the width would be the same for all our builds.
Thanks
M
Old 3rd September 2013, 11:57 AM
Thanks
M
Give Alan Whitehead a ring. He is working on one at the moment to fit the AGM kit. He was hoping to have it ready for next week along with a aeroscreen that will fit the kit (similar to the saturn one).
I am going down there on Friday to get my bodykit and will see if I can take any pictures etc.
How is your build coming along?
Old 3rd September 2013, 12:21 PM
Hi,
Although the width is the same there are differences in the design that may make a difference. I've only really seen 3 pre made ones.
The Equinox one which will likely only fit an Equinox scuttle properly as it has a recess molded into it so the dash they do will fit this recess.
The flat ebay one with the IVA curve on the bottom. I tried to buy one of these but it never turned up and the user is no longer on ebay
That leaves the one that Louthy has on ebay ( looks like its the same one as Gillham provide )
That one should fit any scuttle but looking at the radius on the bottom I'm not sure it meets 19mm radius so may have to be foam covered.
I ended up making my own from leftover aluminium sheet with the 19mm radius on the bottom.
Old 3rd September 2013, 02:24 PM
Thats good news if AGM are making one for their scuttle
Anyone measured one up from a MK etc, there were some nice carbons around aswell that i'd like
Old 3rd September 2013, 03:34 PM
Indy chassis is 5 cm narrower than the roadster...
Old 3rd September 2013, 05:49 PM
PorkChop PorkChop is offline
I have a dash and bubble aeroscreen from Aerodynamix. The aeroscreen looks like it'll fit both the SSC/Gillham and AGM scuttles, the dash will fit the SSC scuttle. You can get them in either GRP or CF.
Old 3rd September 2013, 10:10 PM
I've got a Saturn one that IMO isn't great.
It's about 5mm too short and although it has a curve on the bottom I feel do iva it should return rather than just stop at 90deg to the face.
I'm going to make an mdf one for iva then change after it.
Old 4th September 2013, 12:20 PM
http://www.aerodynamix.co.uk/dashboards.html
Need to check the dimensions against hte AGM scuttle
