Old 6th September 2013, 03:50 PM
Default Lights as a work in progress
Can someone tell me if this has worked please
Old 6th September 2013, 04:20 PM
Gonna have to be cruel Arfon....it just does not look right ,
Old 6th September 2013, 04:21 PM
Its not cruel Kev as I value opinions what is it your not keen on
Old 6th September 2013, 04:38 PM
just the indicator looks "flung on"....angled h/l mount is fine after all that how I did my indy..again just my opinion bud
Old 6th September 2013, 04:42 PM
I would say the ofsetting of the indicator looks a Little strange .
Like the aerofoiled tube though
Old 6th September 2013, 04:50 PM
What might look fairly cool would be if the indy mounting bolt was used as the same bolt for the up/down movement on the headlight,
Old 6th September 2013, 05:42 PM
Oscar Oscar is offline
Same as kev, something just looks a little odd about the indicator there. If it could be out sideways...
Also, that tube and the raised aspect looks awesome
Photos of the project so far:
Old 6th September 2013, 06:38 PM
I see what your saying about the indicator the problem might be that if I send the indicator out to the side it may foul on the cycle wing.
It's easy to remove the indicator the thing I like most is that I managed to get all the wires through the main boss to go down the inside of the arm keeping everything tidy and minimal with the wiring
Old 6th September 2013, 10:39 PM
I've been thinking similar to you, except like the caterham indicators. However I don't think they will go through iva due to being to far in board. It's worth checking the measurements to see if they are ok.
Old 7th September 2013, 07:20 AM
If I may suggest welding a threaded boss to the tube and mounting the indicator to it like this, you can still run the wires through and it keeps them away from the arches.
