Old 18th October 2013, 05:46 PM
rpjg1975 rpjg1975 is offline
Default Ford steering boss for sale
Bit of a long shot but may be of use to someone. I bought a steering wheel and boss at an autojumble and have bought a boss to fit my sierra based roadster so have this surplus to requirements. It is a collapsible boss to fit a ford round column. Mounting holes for the aftermarket wheel are 70mm and 73mm apart so will probably fit a good mix of wheels.
Open to offers if its of any use to anyone?
Russ
Old 19th October 2013, 08:16 PM
Hi Russ,
Does it have the contacts for a central horn button? And does it have the bit to automatically turn off the blinkers (sorry, don't know how this is called in English... well, I'm not even sure how this is called in French too )
Thanks.
Old 20th October 2013, 10:50 AM
Hi,
I know what mean Sylvain. Presume you mean the self cancelling bit. There are no contacts or anything just the boss itself. I'll try to get a pic or can always email u one if you like?
Russ
Old 10th November 2013, 07:29 PM
the bit for the indicators cancel is plastic black sleve that is seprate to the ford steering wheel. you do need a notch cut out for it to locate as the orignal wheel would mind.
also some bosses use the orignal for slip rings for the horn push center
3 little square holes to clip it in. flat blade will pop the old one out
