Old 26th October 2013, 03:23 PM
BenBrooks BenBrooks is offline
Default fuel tank mounting
to mount my fuel tank i was going to rivet a sheet of aluminium on the bottom of the rear tub, so i can mount the fuel pump/filter and anything else i might need there.
Could i sikaflex the fuel tank to an aluminium base which is then riveted and bonded to the chassis? would that pass iva?
if not i would have to bolt the straps through a box section meaning i would need crush tubes which sounds like a lot of hassle to me.
Ben
Build photos: http://s1056.photobucket.com/albums/t362/benbrooks1/
Old 26th October 2013, 03:59 PM
jps jps is offline
Ben
can't you use rivnuts. or rivet on a bracket to secure the strap against?
Old 26th October 2013, 04:05 PM
could also do that. i was only thinking as sikaflex would be the most hassle free way of securing it.
Old 26th October 2013, 07:47 PM
gus's Avatar
gus gus is offline
Hi use rivenuts. Make straps out of 3mm flat and line with stick on rubber
Old 26th October 2013, 08:56 PM
okay cheers guys. didn't think rivnuts would be iva friendly but seems i'll go that way now
Ben
