....it's getting a bit chilly in the Haynes now!
I'll bet....it'll be a bit bracing to say the least!
Russ |
It was certainly fresh!
My fingers were a bit of an odd colour by the time I got to work this morning. Might have to look into fitting some heating elements in my steering wheel! |
How often are you using the roadster? Is it you daily car when it's warm enough? David
Click to see my build photos on Flikr http://www.flickr.com/photos/67112582@N03/ Saturn MX5 Based Chassis, Limited Slip Diff & 2.4 Quick Rack. Build cost.... seems to be spending more on tools than car bits at the moment! (they will be handy in the future though). Car iva'd and passed 15/08/2014. Finished weight 572kg. |
I had been commuting in it 3 or 4 days a week up until the end of September. The last month's been a bit of a washout though, so it's only been out a couple of times ![]() I check the weather forecast before I take her out, and haven't really been caught out yet. I've encountered some very thick fog and a couple of light drizzly showers, but they weren't too bad. It was just a bit of a pain having to constantly wipe my visor ![]() I really don't want to find out what it's like to drive her in a proper rain shower, I imagine it'd be pretty bl00dy horrible! |
You will find that the gap at the bottom of the scuttle and the side panels is very accurate at pointing water at your nether regions,someone on flea bay had a strip moulded for sale to fit on the side to stop it,worth investigating.
Cost : Little as possible. Thanks : To those who by their generosity my build has progressed. Its a handmade sports car not a flaming kit car !!! If at first you dont succeed,avoid skydiving... No parachute require to freefall,only if you want to do it twice. |
I have a window sealing strip on the scuttle flange, so no water is seeping in there. I get all wet regardless, the water from my chest and the outside arm drips into the seat :-/
Albert Haynes Roadster FAQ | Haynes Builder Locations Gallery, build thread in Lithuanian / via Google Translate. |
In the past week we had nice autumn weather, up to 13 degrees and some sun, I took the roadster for a drive. Some warm clothes, beanie, scarf, gloves, and it's great!
Did not seep through seam Albert,it just ran over the gap of the side panel and straight at the undercarriage for some strange reason,aerodynamics of a brick me think's.
Another strange one,sat in Spuds car on track in passenger seat and arm on side (exhaust on left side) as to big to sit in skinny seats and twenty minutes after getting out my arm was stinging from exhaust heat and burnt even though we were not going slow,one to watch out for. ![]()
I dont usually wipe the visor on the bike - the wind usually blows it away. If it is a problem you can get stuff to put on that sheds the rain better(rainex?)
You can always wear waterproof overpants . BUT biker gear is by far the best solution. ![]() |
| Thread Tools | |
| Display Modes | |
