Old 17th November 2013, 01:31 PM
Default Smoke on high temp paint
Hi,
I have started my engine today. First time with the exhaust manifold I modified.
I painted this manifold and the tube with black high temperature paint (650°C).
When I ran the engine today, when it started to heat up, the manifold was smoking a lot from everywhere, a bit like if the painting was burning.
I preferred to stop rather than wait and set up a fire.
Is it normal to have smoke on the paint the first time it is used? Perhaps it is smoking a lot at the beginning, and then stabilizes after a while?
Or did I use a wrong paint, 650°C not being enough?
Thank you for your help.
