Old 21st December 2013, 10:38 PM
Default Mercedes 190 radiator problem.
Sorry to trouble you all, but after reading the posts on here, I have bought a mercedes 190 radiator. The one I have bought is for the w210 car, and it is huge ! What rad are the merc boys using please ? I think that I may have got my wires crossed somewhere ?
Old 21st December 2013, 11:18 PM
sounds like you have a a/c car one
you need the small type!
its is fitted to petrol non a/c manual 190's 1.8-2.3 >93
core size is somthing like 300x340x50mm
auto box ones are the same but have a atf cooling loop
new ones are inexpensive
Old 22nd December 2013, 07:23 AM
Thanks ever so much. I knew that I wanted a merc one straight away, as it was purpose built for the big engined mercedes, so it was perfect for my mx5 1.8. I was worried that a polo or Clio radiator would be a little restricted. I will get this one swapped over. It looks like it has an oil cooler built in, by the look of the additional fittings.
Old 22nd December 2013, 12:42 PM
Incidentally the Polo rad seems fine on the MX5 engine (at least on the 1.6).
I spent a lot of time sitting in traffic this summer and didn't experience any cooling issues.
Old 22nd December 2013, 01:34 PM
Yes it does (gearbox/transmission oil cooling). You don't need to blank them to use the radiator, but I did, so I will not collect craps in it. 2 x M16x1,50 caps will do the job.
2013-11-26_13-50-47 par Voucht71, sur Flickr
2013-11-26_13-50-42 par Voucht71, sur Flickr
Old 22nd December 2013, 03:49 PM
PorkChop PorkChop is offline
It might be worth doing a coolant reroute, that's what I'm planning to do in conjunction with a Polo rad. I just need to figure out the best way to do the fan switch.
Old 22nd December 2013, 07:58 PM
I did two: the VW thermo switch in the rad (£3-4) and fan relay signal from the ECU, both driving the same relay.
And, yes, the Polo rad seemed sufficient for a 2l Zetec during summer.
Old 22nd December 2013, 09:57 PM
Thank you all for your help, once again I owe you all !
Old 22nd December 2013, 10:14 PM
you just cant replace core volume. bigger is always best
mine holds out at 88c with 165bhp
Old 22nd December 2013, 10:16 PM
oh and you can flip it round to have the hoses the other way around if you have a manual one
