Old 5th March 2014, 07:59 PM
Default Help required from a higher power !
What is the best way of joining the Gillham rear arches to the tub please ? I want to use the wing piping, but wasn't sure wether to use 2 bits of plate to sandwich the panels to spread the load or not. The tubs seam to be very thin, & I am not sure of the best way to join it all up without busting the tub.
Old 5th March 2014, 09:46 PM
I used m10 bolts and penny washers either side about 6 per arch. Works a treat.
Old 5th March 2014, 11:46 PM
I pretty much did the same with 8mm and made sure where there was some steel work behind it I tapped it and used it also as a mounting point
Old 6th March 2014, 08:27 AM
I hope you mean 8/10 mm spanner size !
Old 6th March 2014, 12:05 PM
I was thinking that, I used m6 stainless hex bolts for all the bodywork.
Old 6th March 2014, 05:14 PM
Thankyou everybody for the help, it's appreciated.
Old 6th March 2014, 06:50 PM
Hell of a size hole in thin f/glass
