Old 9th March 2014, 04:14 PM
Dualist's Avatar
Dualist Dualist is offline
Default No engine number
I know I'm a very long way off iva and stuff but I've noticed that I have no engine number And as I brought the engine as it was with no car/donor what do I do.?
As the engine is modular (wankel if you didn't know) a friend said buy a new front plate (as that's where they are supposed to be) and make up and stamp a new number on it and I may get an age related plate if I have the receipt. Is that possible.?
Old 9th March 2014, 07:43 PM
Shorty Shorty is offline
I don't think you can just make one up. I'm in the same boat and have a zetec but can't make out the engine number.
As far as I'm aware, the engine number must be real in order to prove where the engine came from ( donor), engine age for tax reasons and to prove not stolen.
I'm not 100 percent. ..
Old 10th March 2014, 08:20 AM
That makes 3 of us as I can't make out the last number on mine but i am going to try a wipe of acid over it, apparently this might bring the number out, wish me luck.
Old 10th March 2014, 08:57 AM
Yeah I tried that. It did improve it but there were some parts I just couldn't see.
Definitely worth a try
Old 11th March 2014, 08:15 AM
Dualist's Avatar
Ah balls
I'll try cleaning down a bit more and see if I can uncover something.
Old 11th March 2014, 03:30 PM
You could try some image processing on a photo after acid etching to try and show the numbers up. Sometimes the camera pics up colour difference that our eyes just dont see and by adjusting contrast levels you can offen get things to show up.
Old 12th March 2014, 09:58 AM
MikeB MikeB is offline
add another to the list. lucky I have the the donor chassis number where I think a bit of it includes the engine number so I can date it.
Old 12th March 2014, 11:05 AM
If you are using a Ford donor and you know that the original engine is in it. Then the last seven digits of the chassis are the engine number. Would start with two letters. For example mine was MU*****
HTH
Old 12th March 2014, 01:05 PM
Thats what I was going to use, I have the donor chassis number plates but can't find the engine number for love nor money.
I will write to ford with that number so get a date l letter
Not sure what to say at IVA though if the engine number is not visible, it would be covered up by the alternator if it was where its meant to be
Old 12th March 2014, 01:14 PM
If it was me and I couldn't find the number on the engine, but I knew what it was from the VIN I would just re-stamp the number into the block where it should be.
Providing all the bits were purchased above board so to speak you have done nothing.
