Old 22nd April 2014, 09:10 AM
Default Speedo cable adapter
Hi,
I just figured out, now that my fuel lines are definitely fitted, that I can't fit the speedometer cable end in the gearbox... not enough room Bad planning again!
Do you know if some kind of 90° adapters exist for MT75? That would save my life!
Also, I cant figure out how the cable stays in place on the gearbox side. There should be a kind of clip, but I don't have it and actually, I don't remember removing it from the gearbox when I stripped my donor. I would be glad if someone could tell me how it is held in place, and even show me picture of the needed part.
Thank you very much.
Old 22nd April 2014, 03:30 PM
rpjg1975 rpjg1975 is offline
You need a circlip.....if memory serves me correctly.......
Russ
Old 23rd April 2014, 01:02 PM
jps jps is offline
I remember exactly how I removed mine - by lifting the gearbox out using the engine hoist - without disconnecting the cable first....
Luckily it bounced off the floor of the car and didn't travel too far - so I found it in the end....!
Old 23rd April 2014, 07:58 PM
Put mine in a safe place until needed
You can get them on ebay
Old 24th April 2014, 11:16 PM
Taped mine to the speedo cable!
