Old 8th May 2014, 12:00 PM
waynes world's Avatar
waynes world waynes world is offline
Default ford MT75 4x4 box mod???
Does anyone know if the MT75 4x4 box can have the transfer box casing cut off and the gears to it removed and then the hole would br blanked off, so them just rear output.
wolly
Old 8th May 2014, 07:22 PM
It would be a masive cludge if it worked.
Either take a scorpio 2.5D RWD box and swap the V6 front casing onto that, or take a 2.0 DOHC RWD box and swap the gear cluster and front casing onto that from the V6.
Don't be tempted to just put the front casing on a DOHC box.
