Old 20th May 2014, 10:35 PM
Badger Badger is offline
Default Attaching pedal box
Evening all
I'm rapidly approaching the point where I'm going to be fitting my pedal box in order to continue building the braking system, and I'd like some opinions on a thought I've had.
I was considering welding the pedal box into position - is there any reason why I can't/shouldn't do this? I can't imagine there is overly much call to remove the pedal box once put in place. Welding it in would save me drilling holes in my floor and bolt heads poking out below it
Old 27th May 2014, 10:33 PM
You're right, there is no point having it removable, unless you'll want to replace the pedals at some point.
Old 31st May 2014, 08:07 PM
Cool, cheers for the reply
