Old 16th June 2014, 07:22 PM
Enoch Enoch is offline
Default More From Enoch
Sooooo, I started on the front wings and had made the offside one but it looked absolutely awful when I put it on the car. I had tried to make it so that it covered the top of the front coilover and associated gubbins but it just looked clumsy and did not give me the look I had hoped for. After much head scratching I came up with a whole new cunning plan. I figured that if I made the front wing stay and headlight bracket out of round bar and made it so the 100mm sphere could not contact the suspension components I could have a much neater wing and not get in to trouble at IVA time. Everything inside the triangle formed by the wishbones is exempt, as is anything below the line of the sill so there is not much left to have to make IVA compliant in that area.
here is the new wing
A different shot:
Just got to make the other side now and neaten this one up a bit then I should be in a position to start glassing all 4 wings and both running boards. I have to work out how much resin and other stuff to buy and will make a test piece first as this is my first venture in to fibre glassing.
Dave.
