Old 27th June 2014, 07:48 AM
Default Plasma cutter
Have been playing with my plasma cutter on some plates for my bellhousing mold This plate is 15mm thick. I think I am going to like this toy
Old 27th June 2014, 09:03 AM
A plasma that will cut clean over 6mm or even be reliable is on my 'shopping/wish' list along with a replacement AC/DC tig that works, 3 phase 250+ amp mig the list goes on and on now I just need the money to pay for some of it....
Old 27th June 2014, 05:12 PM
NeilW NeilW is offline
That looks to be an awesome bit of kit, certainly beats the old chain drill technique.
To carve through 15mm steel that cleanly must be a decent spec.
Nice to see a steady hand action too!!
Old 27th June 2014, 05:57 PM
Dualist's Avatar
Dualist Dualist is offline
Now show us the pic from the other side
But for 15mm cut that is nice and clean, how many amps.?
Old 27th June 2014, 09:04 PM
Ok you lot I have a confession to make . The circle was done with a cutters compass. You put the plasma head or a gas cutting head in there and do perfect circles.
Freehand on 1/2" plate just using a straight edge to follow produces this. makes virtually no slag on the underside.
A gem , I was talked into it by my boc supplier when the gas was on a shortage. I have only just started to play with it , it seems happy up to about 20 ish mm and will sever 27mm bar so good enough for anything I need it for.
Old 2nd July 2014, 07:32 PM
Been messing about with the plasma cutter on some experimental rad mounts in 3mm plate.
As cut and I used a steel ring to use as a guide for the holes. They barely need more than a file run across them.
