Old 6th January 2009, 01:08 PM
MikeB MikeB is offline
Default microblisters in paintwork
I have been looking a couple of lower cost replacement projects for my haynes..
I'm currently looking at the TVR S series.
Project cars can be picked up for peanuts,
One I looked at had microblisteres all over the grp.
What is the likely cause and remedy?
Mike
Old 6th January 2009, 01:15 PM
jasongray5's Avatar
Fabby....?
Old 6th January 2009, 01:30 PM
Osmosis !!?? Caused by water penetration or present during initial lay up.
Thats my starter for 5
Fabby will probably give you the best advice though.
Old 6th January 2009, 02:00 PM
I've got a sneaking suspicion the car has had a respray through
it was a metallic black, not sure how availabel this colour was in the late 80s. mmmm
Mike
Old 6th January 2009, 02:09 PM
fabbyglass
Could be air in the lay up but more than likely a dodgy spray job as grp needs different prep to steel.
The gel coat needs to be really "killed with 80 grit pad on a da"" to get rid of any wax as this attacks the paint, star cracks should be dug right out as will just come back to haunt you even after rubbing down and the appear to have gone....spooky stuff grp but not as spooky as wiring
Old 6th January 2009, 02:11 PM
fabbyglass
There yer go....dodgy paint job!....Oh and it's a car called TreVoR even more dodgy....
Old 6th January 2009, 02:32 PM
so the remedy for a dogey paint job, strip back to gel coat and get done properly...
Old 6th January 2009, 02:46 PM
fabbyglass
I would say so yes but if it's for track day gigglefestage why bother as you are bound to spank it, much better to spend on tyres, underpants and brakes than a shiney paint job..?
Old 6th January 2009, 03:56 PM
yeh thats what I thought.
Helps with the girls though....
