Old 8th August 2014, 12:12 PM
Enoch Enoch is offline
Default Two Steps Backwards.
Been thinking a lot about my front suspension recently. I was really concerned about certain aspects of the geometry and construction. Ended up doing what I probably should have done all along and cut it all off and scrapped it. I have now removed the front sub frame off the jag and will be using that almost as it is to ensure correct geometry and safety. I know this takes it even further from the original concept but I think it's the way to go. I now have it in place but not yet fixed, have to make all the brackets to fix it to first. It needs totally refurbing, am currently waiting for some bushes, a brake caliper service kit and some various bolys and bits and pieces. Already have 2 new discs and pads, springs upper and lower ball joints and track rod ends.Will post a piccy when I have more time.
Old 9th August 2014, 10:32 AM
Smile
sounds like you got a lot of work ahead of you!
