Old 11th August 2014, 01:46 PM
Exclamation Mx5 donor pack for sale ! Plus other bits !
Mx5 1.8 1996 donor pack for sale, bits come stripped from the car and includes as follows, logbook, engine (108,000 miles), hubs, wiring loom, ecu, steering column, set of keys, rear limited slip diff, gearbox etc. save yourself a shed load of hassle, £220 delivered !!!!!!!
Merc 190 radiator, brand new, un used £50 including delivery !!!!!
Mx5 build wishbones, complete front set, rear lowers only, including a full set of poly bushes, brand new bmw top drag links & brand new mx5 lower ball joints, only £150 delivered !!!!!!!!!
Rally design coilovers including springs, brand new, unused £230 including delivery !!!!!!
Mazda mx5 original steering wheel mk1 for sale, iva friendly, lovely condition, £30 including delivery.
No reasonable offer turned down, everything must go !!!!!
Old 11th August 2014, 01:52 PM
jps jps is offline
Looks like you're selling up Jason? Sorry to see that if you are.
What lengths and spring rates are the coilovers?
Old 11th August 2014, 02:04 PM
You got it, split with the wife & need the cash. Not completely gone though, I am storing the completed chassis, so I will have a head start when I have the cash. Front coilovers are 14 inch open eye to eye, with a 325lb set of springs, rears are mx5 spec, about 12 inches or something like that with a 225lb spring set up. Coilovers are still boxed and un fitted, 1.9 inch ram, and are made by Gaz.
Old 11th August 2014, 03:43 PM
jps jps is offline
Ah - I am doing a Sierra build which I think is 14's all round.
Sounds like you've got other things to concentrate on, hope it all pans out well for you in the long run.
Old 11th August 2014, 04:50 PM
garyt garyt is offline
hi Jason, sorry to hear your circumstances, went thru it myself out the other side now and back building, so, I know its tuff but keep in touch it's to easy to drift away.
Anyway thanks for the tank and best wishes
gary
Old 11th August 2014, 06:37 PM
Thankyou both. Sorry about myhermes, they are usually spot on, but the last 3 parcels that I have sent out took too long for my liking.
Old 11th August 2014, 07:19 PM
its no problem honestly you have enough on your plate, just take care of yourself
Old 12th August 2014, 06:13 PM
Bump bump o
Old 17th August 2014, 01:43 PM
See new prices !!!!!!!!!!!! Look at my first post.
