Old 18th August 2014, 11:27 PM
onedayTM onedayTM is offline
Default remote brake reservoir!
reading your threads and have got to the stage where I need to sort the braking out.My sierra master cylinder is pretty grotty and in need of some attention, looked at new one but are expensive so do I fit new seal and piston kit, but how do you make sure it is cleaned and not have any crap in there to block fluid? what replacements are there that are duel circuit. Also I am looking at fitting remote reservoir as I have read that will be best for low fluid warning! what fittings are available to attach pipes as they push into master cylinder. hope this is not to much to ask.
thanks
tony
Old 19th August 2014, 10:33 AM
This has been discussed on here before so if you search for it you will get some answers,Fiat Punto remote resovoir will do and hou can use the fittings in your cylinder.
