Old 21st August 2014, 11:57 PM
onedayTM onedayTM is offline
Default propshaft measurement.
how to measure for propshaft? how much do you allow for movement at gearbox spline?
tony
Old 22nd August 2014, 09:20 AM
Oil seal at g/box end to prop flange,check the shiny bit on the old prop and that's how far it has sat in the rear bush of the box.
Any good prop manufacturer will account for this.
Old 22nd August 2014, 11:54 AM
Change the gearbox oil seal as well. It's easy when the engine is out but a right pita when it's in and plumbed. The type9 one is only about £7 on ebay.
Old 22nd August 2014, 08:44 PM
mgglep's Avatar
mgglep mgglep is offline
I would say you need about 30 to 40 mm of shiney bit out of the gearbox to allow you to get the prop in and out and to allow for the small movements in the engine
My Build pics
Old 22nd August 2014, 09:46 PM
cheers guys, got oil seal ready to go when engine comes back out.
tony
Old 23rd August 2014, 09:46 AM
Shiny bit sits in a bearing bush,the further it is in the more bearing surface is used,and the diff no longer moves as in a live axle and that was the point of having that sliding joint.
Old 23rd August 2014, 01:14 PM
I left a distance on 25mm. Easier to remove and allows for any small discrepancy in manufacture or final build.
