Old 16th September 2014, 01:41 PM
Default Type 9 and prop.
Just a little heads up on the above,its possible that the prop may not be fitted far enough into the bush in the tail shaft if the shiny portion is not in far as it should have been originally.
There is a gap behind the seal of about 10 mm before the bush and the bush is about 50mm long,just bear in mind what could happen if it decides to let go .
