Old 6th October 2014, 08:09 PM
Default MX5 Sump... mad idea?
So now my build is nearly over, my mind has inadvertently been thinking of other matters/puzzles. I never liked how much the MX5 sump hangs down. I've no doubt it'll take a good solid whack or two to damage it but still. A sump guard only makes grounding out issues worse, I've found. So.... I thought about chopping sumps (it's cast alloy), dry sumps (stupid expensive). And then thought, "hang on, what's the mazda 1.6 323 sump made from?".
http://www.ebay.co.uk/itm/ADM561201-...em462464 fbe3
Steel! So chop one of them instead and fit that? Anyone see any issues with this, other than it won't bolt up to the gearbox?
This is a post IVA thing btw.
Old 6th October 2014, 08:43 PM
It's a crazy idea, but it might just work!
I've been scraping my sump fairly regularly recently
I think my suspension must have softened over time as it never used to hit the ground.
One of my winter jobs is to come up with some kind of guard. Or possibly just raise the ride height if I'm feeling lazy
I'll be interested to hear if this idea works though!
Old 6th October 2014, 09:10 PM
johnl63 johnl63 is offline
been thinking on those lines this morning
check out
http://forum.wscc.co.uk/forum/index....ur-sump/page-2
Haynes MX5 based New Zealand
Old 6th October 2014, 09:30 PM
PorkChop PorkChop is offline
There should be no problem with welding the ali sump; it's been done before.
But IIRC the later 1.6 90bhp sump is steel.
Old 6th October 2014, 11:22 PM
No it's Ali. I have a 95 1.6 90hp. Apparently cast Ali is difficult to weld.
Old 6th October 2014, 11:55 PM
My main concern is losing 4 of the 8 bolts that hold the engine to the gearbox!
Old 6th October 2014, 11:59 PM
Sump looks very strong/structural don't you think?
Old 7th October 2014, 08:28 AM
I think you are correct in saying that it 'was' structural as you need to remember how the back of the gearbox was tied to the nose of the diff, if there was only four bolts around the top of the gearbox the diff could have snapped the bell housing under load.
How ever in the Roadster you support the back of the gearbox on it's own rubber mount in the tunnel, it does not have the diff acting on it you could in theory get rid of the bottom section.
There is a 200sx in the unit next to me making near 280hp and that has only ever had four bolts holding it together and that is used for drifting. I personally would spend the £25-60 that the steel item costs on paying some one to TIG the cast ali item once I'd worked out the sump oil pickup.
Old 7th October 2014, 09:32 AM
Oh really, that's interesting. Looks like something worth trying then. Cheers
Old 8th October 2014, 08:24 PM
You're right, my apologies, got confused with another Mazda engine.
