Old 9th October 2014, 10:31 PM
Default Last inspection passed!
Last inspection for the road certification of the Roadster this afternoon. All good: it's a «Pass». The inspector, after the test drive, even told me «it's a good car, very pleasant to drive»! And if there are some swedes over here, they will understand even more the meaning of these words knowing that my inspector is Bosse Bildoktorn! Just a thing he asked me to think about and improve (but not enough for a "fail"), are the front wing stays, they are vibrating a bit too much, in spite of them being made of 5mm x 25mm steel strips. But I have the whole winter to think about that!
Well, anyway, it is not over yet, still have to pass the noise test, and MOT. But we're getting there!
Weighting the car
2014-10-09_17-07-17 by Voucht71, on Flickr
Bosse (the inspector), in the car before the test drive, and me
2014-10-09_17-28 by Voucht71, on Flickr
The Roadster has been weighted at 680 KG, with a full fuel tank (34 liters) and no driver/passenger. I was expecting less, but I know I haven't really worked on the weight, running a 2,0i DOHC from a Sierra, steel frame seats, and so on... what is the average weight of a Haynes?
Anyway, it is a relief!
Old 10th October 2014, 02:14 AM
raceral raceral is offline
Congratulations on your successful pass.
I also used the same size material for my stays and they too vibrate, mostly at idle.
So far after a year they have done nothing more than vibrate and have not been a problem.
Al
1969 Amx
2004 Passat 1.8T 5Spd 4Motion
Haynes Modified Super 7 3.4L V6
www.lotussuper7replica.com/
Old 10th October 2014, 08:26 AM
Talking
Well done that man
Old 10th October 2014, 08:38 AM
jps jps is offline
Originally Posted by TheArf View Post
Well done that man
+1!!!
Congratulations, inspiring for my own build!
Old 10th October 2014, 09:52 AM
Janne E Janne E is offline
Congratulations
Your Roadster looks real good
Let´s hope you got the MOT real soon so you have everything ready until next spring.
It´s Three years sinse I got mine at the road so today was the first time I have to go to the MOT ( kontrollbesiktning på svenska) and it was no problems, got the thumb up from from the testman
Janne
Old 10th October 2014, 10:07 AM
Well done on the pass. It's a great feeling.
My stays are 6mm x40mm and only vibrate at 80mph and not that badly.
My car was a bit fat but I did over engineer some of the added parts. With me in it (100kg) and 36L fuel it was 720kg.
Old 10th October 2014, 11:55 AM
Nice one Syl ....yep those stays will annoy the hell out of you... but hey get it on the road first.
Old 10th October 2014, 12:14 PM
Ditto all the above congrats ,I recognise those stripes
Be carefull with the exhaust,you may/will find the gas will burn your arm if you have it on the side panel as I found out being a passenger in Spuds car,even when driven hard round a track it burnt the underside of my forearm.
Good luck/Bon chance.
Old 11th October 2014, 01:43 PM
Thanks for the nice words my friends
I'm gonna fix this stays this winter, perhaps brace them with half round tubes. And for the weight, that is something I can work on along the way.
@ Janne: perhaps next spring I can drive down to Skåne with the Roadster and we go for a drive together?
Yesterday, I drove 400 km round trip to take a 10 minutes noise test... It was a pain to drive such a long way with the Roadster on the trailer, just for that, but no choice, it had to be done. I was worrying a bit about the noise with my motorbike exhaust muffler (BMW R1300K), pretty short, with an integrated catalyst converter. But I passed the test! Readings were between 77 and 81 dB, max authorized is 84 dB. So I'm happy and relieved that this inspection and noise test are behind me now
Next step will be MOT, and I already know, from the inspectors, that I will have to change my seat harnesses, 4 points are not authorised on road in Sweden, and I hadn't noticed that on the manual. I might also need to weld a stainless steel elbow to the tail of the exhaust muffler to respect the exhaust gas outlet angles. I will also protect my rear wing.
But after all the stress from this end of the week, the Roadster is back in the garage, garage is locked, and I'll just take this week-end to relax and think about something else
Old 11th October 2014, 02:28 PM
Hi Voucht!
You are moore than welcome to the westcoast for a drive together
I have both 4 and 3 Point harness mounted all the time.
//Janne
