Old 19th November 2014, 06:29 PM
garyt garyt is offline
Default help !!!!
Ok I need help with this one please, this is from a mk2 mx5 and lived , on a bracket, beside the boost sensor.
I've googled it and have conflicting answers !!!!
so what is it, what does it do and do I really need it?
If its to do with the egr then where do the 2 pipes go to and if its part of the evap then I don't need it.
Just worried that it has electrical socket and trying to avoid it triggering any fault codes if omitted.
Thanks in advance Gary
Old 19th November 2014, 06:42 PM
If the egr works on vac thats what probably controlled it,vac in on one pipe and out on the other through the solenoid to valve.
Old 19th November 2014, 07:04 PM
thanks will go out later and see if there are any vac points on the egr valve its self
Old 19th November 2014, 08:30 PM
Looks like the solenoid that controls the fuel evap cannister fuel thingy. Got rid of mine along with the evap stuff.
Old 19th November 2014, 08:33 PM
It looks like the evaporative canister solenoid / valve. I cannot remember its name but it goes between the carbon canister and the inlet manifold. I tookine out.
The ecu will bring back an error code but that's ok.
Old 19th November 2014, 09:20 PM
thanks guys duly consigned to box of bits not needed
many thanks Gary
