Old 15th January 2015, 02:54 PM
Default Offset on mushroom inserts
Hello,
I discovered that some guys are using mushroom inserts with the hole for the drag link centred, like on the Locost, and not offset as we do and as the books says.
I find it strange, but I can't really explain why on the Haynes Roadster, this hole is offset? It gives a bit more caster angle, OK, but is there another reason?
Thank you.
