Old 8th February 2015, 03:24 PM
Default Is my steering rack right?
Trial assembled the front suspension and steering this afternoon and I've got massive toe-out.
I'm using rack extensions from eBay which are 30mm shorter than the book length.
Measured the rack and it's about 600mm between the inner ball joints, and each arm measures 370mm each side ball joint to ball joint. Is this standard rack dimensions for a mk2 escort rack, or have i been sold something bigger by mistake?
I've read that the capri rack is the same inner but with longer arms.
