Old 12th April 2015, 05:53 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
Default hubs question
The brakes I just got have vented discs and placing them up to the hubs I have it seems the studs are very short so I am assuming the original hubs donor had solid discs so my question is...
is there any difference between the hubs for solid discs and the hubs for vented discs and what length should the studs be to use the vented discs
Old 12th April 2015, 07:21 PM
Sierra?
Should be the same for vented or solid.
Old 12th April 2015, 08:02 PM
vmax1974's Avatar
Thats ok then was just wondering cause they did look a bit short
Old 12th April 2015, 09:09 PM
rpjg1975 rpjg1975 is offline
My J reg Sierra donor had venteds fitted iirc but I can check the stud length for you tomorrow if you like?
Russ
Old 12th April 2015, 09:40 PM
vmax1974's Avatar
That would be great thanks ones on mine are 47mm
Old 12th April 2015, 11:37 PM
Okey dokey, will get back to you....
Old 13th April 2015, 07:26 PM
Mine are the same.....47mm
Old 13th April 2015, 07:43 PM
vmax1974's Avatar
Thanks for that
how your car coming on
Old 13th April 2015, 10:58 PM
About where it was when you last saw it been one thing after another with long term sickness, moving then unemployment but been picking up bits here and there and will get cracked on again soon
