Old 8th June 2015, 04:19 PM
james3004's Avatar
Default Headlamp flash sierra
Wired up my headlights at the weekend and they all work fine apart from the flash.
Am I right in thinking this is a problem with the switch?
--- James ---
IVA passed 20 June 2017
Flickr Album
Old 10th June 2015, 11:18 AM
Are you using the later style Sierra switched earth column switches?
If so have you got pin 15 of the indicator / dip-main beam switch connected to earth? This is the pin that the main beam relay earths through when flashing the lights.
Old 10th June 2015, 11:36 AM
james3004's Avatar
They're from a 92 so I guess they are the later ones
Will have to check that out
Thanks
--- James ---
Flickr Album
Old 11th June 2015, 07:27 AM
james3004's Avatar
Checked it out and that was the problem!
Thanks it saved me a whole load of grief and head scratching 😀
--- James ---
Flickr Album
Old 11th June 2015, 10:34 AM
No worries, glad you got it sorted
