Old 1st August 2015, 06:43 PM
garyt garyt is offline
Default mx5 master cylinder banjo wanted
hi folks has anyone got a banjo , no not hillbilly
I need one off an mx5 master cylinder its a 10mm banjo with a female thread on the pipe end.
I had one off a mk2.5 master cylinder but need another one.
thanks in advance Gary
Old 2nd August 2015, 09:53 AM
Ianr Ianr is offline
I replaced the banjo on mine with a 10 x 1 mm long male pipe connector - if you can't find one.
I was also told that the banjos are likely to cause issues with bleeding as detailed here
https://sites.google.com/site/hydrau...lable-fittings
Ian
Old 2nd August 2015, 04:08 PM
Hi Ian , thanks for that , I knew about their inherent problems I just need one to sort out a clearance issue.
regards Gary
Old 2nd August 2015, 08:12 PM
sorted out thanks
