Old 29th January 2016, 09:55 PM
Default mild+stainless exh. manifolds
I've finally got a new toy in the workshop a rotary draw bender which means I can bend round tube with 2-2.5-3mm wall in mild steel ERW, CDS and 304 stainless tube in sizes 38mm and 42mm which can be used for exhaust manifolds in 4-2-1 or 4-1 primaries and a 50mm exit.
Given that all the chassis are the same I should be able to make custom exhaust systems if I'm given the position of the exhaust flange relative to TR1/2/8 and where you want the collector to exit on the chassis.
Prices will start from £300.
