Old 25th April 2016, 09:04 PM
norton norton is offline
Default Concrete for a desktop, anyone done this or similar?
Hi guys,
I'm looking to make a new desktop to sit on the singer sewing machine legs I'm currently using.
Problem is, I've never used concrete and I've no idea about the mix ratios. There's plenty of premixed concretes and mix ratio info about however these are for building houses etc. They appear to use coarse aggregates which could show through the surface of the concrete however I'm after a smooth slate like finish and no idea what type of mix would achieve this.
Help!
Old 25th April 2016, 10:28 PM
SteveH1 SteveH1 is offline
For making a slab a course aggregrate is going to be stronger than a sand mix
If it was me i would make a mould out of mdf and seal it with pva glue so the bottom of the mould will be the top of the table this will get the smoothest results
Then mix the concrete to the required mix and add to the mould and smooth over
then band the outside of the mould to try get the air out
this will be the biggest problem with trying to get a smooth to getting the air out
You will also need to rum rebar through it for strength
Google diy concrete counter top
Old 26th April 2016, 07:12 AM
RichardH RichardH is offline
why not use a bit fireplace marble instead?
Old 26th April 2016, 06:57 PM
That is pretty much my plan but using melamin faced board instead of mdf. I'll go wit the coarse aggregate, maybe I'll even cheat and by a premixed bag. I'll post up my results once I've buggered it up.
It'll be even heavier, more expensive and harder to work at home. I like th elook of the concrete counter tops too.
Old 26th April 2016, 07:08 PM
vmax1974's Avatar
vmax1974 vmax1974 is offline
You could make a form and use resin as it would be far lighter than concrete but could be made to look the same just my thoughts
Old 26th April 2016, 07:42 PM
I did consider using resin but, kerr ching.
