Old 2nd August 2016, 07:15 PM
CarlW CarlW is offline
Default Sierra Front And Rear Uprights
Hi Guys,
Couple of quick questions.
Does anyone have measurements for the rear uprights to accomodate Sierra hub carrier (6 bolt type for rear disc)
What ball joints options do I have for the lower ball joints on the front hubs?
I have read about some needing reeming out.
I can CAD design new lower wishbones and have parts made as needed.
I do have a full set of Cortina hubs etc but told these are no good for a Haynes Roadster?
Cheers All!!!!
Old 3rd August 2016, 08:23 AM
The rear plate is the same for disc/drum only orientation is different to clear caliper.
Sierra hubs do need to be reamed out and Cortina parts geometry is wrong for Haynes set up as far as I am aware.
Old 3rd August 2016, 08:30 AM
Hi,
Where can I get the measurements for the rear plates as the CAD model I have must be for something else, not Sierra.
Cheers!
Old 3rd August 2016, 01:46 PM
From the book or buy from ebay.
Possible someone will have in CAD of other format.
The rear carrier is only different to take the caliper mounts,bolt hole pitch is the same.
