Old 26th September 2016, 07:31 AM
CarlW CarlW is offline
Default Ride Hight
Hi Guys,
Have any of you got a good ride height measurement? From chassis to ground.
Cheers,
Old 26th September 2016, 09:38 AM
TSM Locost's Avatar
westfield set seiw at 146 front and 160 rear, sump clearance I would not like to be less than 80mm for road use.
Be Lucky, Mike.
Old 26th September 2016, 11:10 PM
For the book Haynes Roadster, with the lower wishbones horizontal, it works out at about 11 cm front, 12.5 cm back, give or take 1 cm. Since the engine sits 25 mm lower than the chassis in the book design, the ground clearance at the sump is about 8-9 cm.
Old 27th September 2016, 07:07 AM
cheers guys, I will get in my CAD and see what it looks like.
Old 27th September 2016, 05:20 PM
Have you seen this? https://grabcad.com/library/haynes-roadster-chassis
Old 27th September 2016, 09:29 PM
Ianr Ianr is offline
Mine is set at 140mm front and rear but with the sum p a bit lower ish
