Old 29th September 2017, 08:28 AM
chris_smith chris_smith is offline
Default Mx5 lower ball joint
Anyone had Iva using Mx5 lower ball joint needed to add a lock nut to the short bolt that goes into a thread?
Old 29th September 2017, 09:45 AM
Interesting question...in theory the bolt only being held by the threaded part of the ball joint means it's not locked, how ever if you add a nyloc or even drill that out to 12mm and replace with standard M12 bolt and nyloc it is considered locked. You could of course try and find a castle nut and split pin it if you can drill through.
This the reason I don't weld the nuts on the under side of CP3/4 as using nylocs is one less simple fail to worry about...
Old 13th October 2017, 07:03 PM
Cropper Cropper is offline
I didn’t but I did add loctite
