Old 15th April 2009, 09:54 PM
davidimurray's Avatar
Default IVA run through - Complete Kit Car Magazine
While out and about today I noticed the latest issue of Complete Kit Car in the newsagent. One of the features is a run through of the IVA process which makes for interesting reading.
Some interestings things I've picked up are -
Chassis number must be on the RHS
Brake fluid reservoir must be labelled with type of fluid
All controls must be labelled - including the indicator stalks
Centre rear view mirror must be permanent - no stick on ones!
Changes to the way cockpit protrusions are measured
Cars will need either a steering lock, or profesionally fitted immobiliser
All outboard seats must have headrests
New method of assesing wheelarch coverage which looks like it will affect us
Filler cap must either be operated by the ignition key or tethered to the car
Changes to lighting requirements
Twin master cylinder brake setups must have the balance bar WELDED up to prevent future adjustment
Noise test dropped to 99db.
The article is not a full in depth look at the IVA, but makes interesting reading.
Old 16th April 2009, 04:11 PM
fabbyglass
Outboard seats.?????? ummmm interesting thought...200hp outboard with a seat and yeeeeeeehaaaaaaa no need for a boat
Old 16th April 2009, 04:39 PM
Hmm - a 4 seater roadster - 2 inside - 2 outside!
Mark - will your arches fit the new IVA, I'm guessing your seats will be fine, apart from the low back which I guess will need a head rest.
Old 16th April 2009, 06:16 PM
Tablets Mark needs.....
Old 17th April 2009, 11:49 PM
fabbyglass
Yes wings are ok for IVA bods but some donor bits won't be..
Old 17th April 2009, 11:54 PM
which donor bits?
Old 17th April 2009, 11:57 PM
fabbyglass
Well IVA will test from behind the front wheels as well as in front unlike SVA so calipers for one..!
Old 17th April 2009, 11:58 PM
fabbyglass
The car also has to be in telemagenta or won't stand a chance of passing...
Old 18th April 2009, 12:00 AM
oh dear??? i suppose its in case i reverse over someone no doubt we,ll find a way around the new regs to satisfy them.
Old 18th April 2009, 12:02 AM
fabbyglass
Rules are made to be broken and some are just potty like those in the IVA test but mainly it's a good thing as keeps things to a standard.
