Old 22nd April 2009, 08:38 PM
Default Rear Wheel Clearance
Hi
I fitted my rear wheels last weekend. While I was fitting them I notice that the bottom wishbone and upright have very little clearance between the rims. The rolling chassis touches the rim in places.
I have reduced the threaded bar to the shortest length possible, however I have maintained the washers on each end as I assume this retains the bush tubes. I have not get fully tightend the hub nuts. I am hoping that when tightend this will rectify the issue but did not want to use the nyloc until final assembly.
Do I need to either?
1) Buy larger rims?
2) Make ali spacers to increase the distance by 5-10 mm?
3) Tighten the hub nuts as the nylocs will not make any diffrence if already self tapped?
Has anyome else had similar issues?
Old 22nd April 2009, 08:46 PM
the hub was designed for 15inch alloy wheels. if you want to go smaller you will need to make new bottom wishbones that use rose joints.
failing that, its a hub redesign. its the worst part on the roadster if you want to go racing with 13inch wheels.
every problem has a solution its just finding it
Old 22nd April 2009, 08:48 PM
Spikehaus you have PM
Old 22nd April 2009, 10:13 PM
Thanks Ash,
I have been trying to find a valid argument to justify spending more DIY money on new rims! That's just what I wanted to hear!
Old 26th May 2009, 02:43 PM
axle's Avatar
axle axle is offline
Thumbs up
I like to fit 16" by 205 low profile, I am not sure what wheels to use to have enough clearance in the back with the stanadard wings!
Any idea it will be appreciated!
Regards Axle
Old 26th May 2009, 06:10 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi guys which area of the rear hub/wishbone causes the problem?
I was hoping to use the 14" wheels from my donor especially as i spent so long last week cleaning them up!
Old 26th May 2009, 06:42 PM
dogwood's Avatar
dogwood dogwood is offline
OOOPS!!!!
You will find the lower mount's where the upright fits the wishbone fouls the rim if you try to use anything smaller than 15's.
Old 26th May 2009, 06:56 PM
I have some lovely scuffs around the inside of my 14 inch alloy rims as evidence of this! To get around the problem on a temporary basis, I purchased some ali spacers for about £12- 15. This has allowed me to to complete the rolling chassis until such time that I wish to spend out on the bling bits.
Originally Posted by dogwood View Post
OOOPS!!!!
Old 27th May 2009, 01:17 PM
RAYLEE29's Avatar
So does anyone have a picture of the area that hits so i can change the design to suit pls
Ray
Old 27th May 2009, 01:26 PM
axle's Avatar
I really can see what your concern is , as the the car in the book was fitted with the !4".
AXLE
Regards Axle
