Old 9th May 2009, 05:32 AM
michmark michmark is offline
Default Rear subframe bushing problem
I am stripping out a Merkur XR4Ti (the Sierra in the US) and have run into a problem. The 19mm head bolt that goes through the large rubber mounting donut has rusted thoroughly to the metal sleeve that runs inside the rubber. To compound the issue, the captive nut is no longer captive and the bolt, sleeve and nut spin around without loosening. Cutting the head off of the bolt relieved some frustration on my part but did nothing to let the subframe drop down from the body.
Any suggestions for how to attack this?
Mark Bates
Old 9th May 2009, 06:22 AM
jasongray5's Avatar
perhaps cutting around the mount (thus creating a hole in the chassis) then sorting it out when its on the floor?
Old 9th May 2009, 09:55 AM
oxy-acetylene?
Old 9th May 2009, 02:26 PM
Tilly819 Tilly819 is offline
Iff in doubt, get the angle grinder out......... hey that even rhymes teehee
Old 9th May 2009, 07:43 PM
BFI,brute force and ignorance. The suggestion of hole in chassis makes the most sense as you could possibly remove the cap nut,if not attempt to cut sleeve and bolt between frame and chassis.
Good Luck.
Old 11th May 2009, 03:58 AM
Thanks for all of your suggestions. I have also thought of using my propane torch (I don't have Oxy-acetylene) to burn out the rubber bushing. Probably will be messy and toxic so this will be the last desperate attempt.
Mark Bates
Old 11th May 2009, 10:29 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, just a thought, do you actually need to remove the subframe? I have taken out my diff and driveshafts and soon to be taking out hubs but leaving subframe in.
Ray
Old 11th May 2009, 08:49 PM
Dont forget to loosen the hub nuts first!
Old 11th May 2009, 09:29 PM
Who would do a silly thing like that.
Old 11th May 2009, 10:51 PM
aaronbassett aaronbassett is offline
me lol ash would vow for me. i took my rear sub frame off with out undoing the 41mm hub nuts
my blog
Building is just another word for progress
