Old 3rd July 2009, 07:57 PM
Default Alternator Mounting Bracket
I have reached the point of locating the alternator. After undertaking a search on the subject it appears that little information has been posted.
The book show a new bracket. Does anyone have a photo of the new postion in-situ that I could refer to as a refference point?
Old 11th July 2009, 11:15 PM
I managed to solve this one. I am going to flip the alternator over and mount it with the area above the steering rack. By mounting it on the nearside, it will allow the drive belt to run the alternator in the correct direction directly of the engine and also run the water pump.
I will post a photo of this and the bracket when I get round to making one. Hope it helps someone somewhere down the line.?
Old 12th July 2009, 07:51 AM
dogwood's Avatar
dogwood dogwood is offline
Hi Spike.
Don't quite get that
I'll wait for the pic.
Here is a pic of the bracket I made.
I think it was juat a case of mounting the alternator an inch or so higher
Old 13th July 2009, 09:20 PM
Thanks David
The problem I am having is, after fitting that beast off a V6 engine with a close ration box, there is no way that the alternator will fit! Hope to make the brackets before the end of the month.
Old 1st August 2009, 08:43 PM
I'v done it!
This is the mark 1 bracket, I will refine it tomorrow by removing the top section of the bracket that is surplus
Old 1st August 2009, 08:53 PM
nice work there mate,
tho it makes me grateful that i,ve only used the cvh engine
wait till you fire her up the first time, that,ll make all the work worth it eh...
Old 2nd August 2009, 03:33 PM
Does anybody know of a good supplier of alternator belts in varies sizes?
Old 2nd August 2009, 09:33 PM
walk into halfords and get one. they usually have loads hanging out on display
Old 2nd August 2009, 10:59 PM
davidimurray's Avatar
On p82 of the book, Chris has a 'rough' drawing of what is needed for the new alternator bracket. Does anyone have the baseplate dimensions for a 1.8 Pinto? I'm gonna get a load of stuff laser cut so was gonna be lazy and get this done at the same time
Old 2nd August 2009, 11:26 PM
nice to see you putting the mill to use spike
