I started to fit the front suspension brackets and found that I have a gap between the chassis and the bracket. I have checked the frame dimensions and they seem OK. I had a word with Spikehaus as he had the same problem. There is apparently a thread on this but I can't find it.
Should I place a spacer between the chassis and bracket or should I manufacture new brackets with the dimension to the bracket hole altered to suit? Thoughts and ideas appreciated ![]() |
| Thread Tools | |
| Display Modes | |
