Old 20th July 2009, 12:38 PM
drury318 drury318 is offline
Default Question for Bonzo
Bonzo, trying to get my chassis ready for painting but cant decide where headlamp brackets go, how did you decide how far out your`s stuck?
Thanks Dennis
Old 20th July 2009, 01:01 PM
Hi Dennis
The book states to suit lights & as I do not as yet have them, I decided to err on the side of caution
Much easier to cut a small amount off rather than try to add a piece in.
I made the oval tube & cut it to 120mm
Having an offcut of 47mm od pipe this was used
I ended up with an overall length of 167mm
Having fitted the front roadwheels 15" X 195 & turning lock to lock, plenty of clearance for a 6" or 7" headlamp unit.
I hope this is of some help to you
Old 20th July 2009, 01:05 PM
That`s great, I will follow your lead, off to the garage I go!
Dennis.
Old 20th July 2009, 01:26 PM
fabbyglass
Use a bit of flat oval welded to top rail where the top shock mount is on the chassis...cut the oval tube to 95mm long then weld a piece of 2" diameter tube about 25" deep with a penny washer welded on top. Bolt yer lights to that and jobs a goodun as they say or simples if you are a meerkat!!!
Old 20th July 2009, 01:28 PM
fabbyglass
Forgot to say cut one end of the oval tube to same angle the top rail is...think it's a 10degree cut this will have the brackets at right angle to centre line of the car.
Old 20th July 2009, 01:38 PM
Nice one Mark
More or less within those measurements then, About 20mm longer
Yes the angle of the cut was 10 degrees
Old 20th July 2009, 01:42 PM
fabbyglass
That was from memory as been awhile since properly made one for folk but somewhere near...I gusseted the bracket to top shock mount as well.
Old 20th July 2009, 02:20 PM
Thanks for that, whilst you`re on Mark, did you measure the bonnet bulge for me as regards how high the bulge is and how far back it starts to rise? Dennis
