Old 22nd July 2009, 09:41 PM
Jimmyd Jimmyd is offline
Default Gearbox mount
Chap,
I'm not overly happy with my gearbox mount quite a bit of movment in the rubber block and because I've lifted the engine quite high for max clearance the box should probably be raised a bit. I'm toying with making a bracket with bobbins on either side, do you think exhaust type bobbins would be up to the job?? The bracket would be compressing the bobbin not stretching it.
J
