Old 23rd July 2009, 12:13 AM
jasongray5's Avatar
Default Fuel pumps?
Fuel pump confusion...
Right, Im going for ms 1.8 zetec on r6 tb's
Is it better to have a hp pump near, the tank with an integrated swirl pot
Or is it better to have a cheapo facet pump, feeding a swirl pot in the engine bay. Which then feeds the HP pump which feeds the throttle boddies?/??
CHeers guys
Old 23rd July 2009, 06:54 AM
To keep things simple, if you don't already have a tank, go for one with a swirl pot or sump built in, and then just go for an injection pump - less stuff to go wrong! Vauxhall astra/cavalier injection pump is cheap, got mine on ebay £20 brand new.
Adrian
Old 23rd July 2009, 10:04 AM
jasongray5's Avatar
cheers adrian, thats exactly the answer I was after!
Did you mount inside or outside the tank?
Old 26th August 2009, 08:12 PM
Help!!!!!!!
I have purchase a custom fuel tank with a sump, the manufacture advised I do not require the swirl pot as well. I am running a Sierra xr4x4 2.8 l MFI engine. I have purchase a replacement fuel filter as per the original car (1986)
What type of fuel pump do I require? I have been searching the bay and like the Redtop. Silvertop or solid state.
Old 26th August 2009, 08:40 PM
drury318 drury318 is offline
You need the same fuel pump that would have been on the car, did you keep it? it looks like a filter but with 2 wires on it, probably mounted near the filter?, if not you can find them on ebay new from £40 upto £140! just look for V6 Ford pumps etc,
Dennis
Old 26th August 2009, 08:47 PM
I was hoping to retro fit a Facet pump? Ok, wish I had kept it now!
Old 26th August 2009, 08:53 PM
sorry if i,m wrong but surely you can change the pump for a new more modern one as long as it can provide the correct pressure,??
if i,m wrong i,ll crawl back under my stone
Old 26th August 2009, 10:42 PM
les g les g is offline
Spike i have an in tank pump goin spare if its any use from the 2l dohc donor
you,ll have to check it wil supply enough for your v6 first though
cheers les g
