Old 31st July 2009, 06:14 PM
Default Rolling Chassis
Well its the classic milestone of having the running gear on. I've using odd sets of wheels to push it around on. Hopefully I'll have the cash for some alloys later on. Engine is the 16v RS2000, onto a type 9. I've found out the painful way, unless the whole gearbox / engine sits forward 6 inches, I can't use a RS2000 alloy bellhousing
I plan to strip it this weekend, finish off some odds and sods welding and get it painted.
Old 31st July 2009, 06:18 PM
May I be amongst the first to offer my congratulations. Looks groovy.
Old 31st July 2009, 06:28 PM
Cool Well done that man
A very big well done on reaching this milestone
Looking mighty fine
Look at all that build space you have
Old 31st July 2009, 07:03 PM
a big well done, its looking great
i bet you can,t stop looking at it now can you???? go on be honest
nice one, thats another rolling chassis that hopefully will be at stoneleigh next year.
Old 31st July 2009, 08:19 PM
Well done mate
I think a few people have reached this point recently. Since I got mine in everything has stopped! Still big plans to build the alternator brackets tomorrow and modify the remote gear linkage so it does not foul on the prop.
I used the Ford V6, so I struggled to get the engine back far enough. Still the remote lever should sort that.
Everyone missed Bonzo big day, rolling chassis and engine mounted. Maybe Ronnie will post a pic for the benefit of anyone who cant see it in the flesh?
Old 31st July 2009, 08:57 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, firstly well done looking good.
second which rs 2000 bellhousing did you have? from a mk2 escort?
the reason i ask is because that is what im using and its fitted in there ok but i did make my chassis to the mt75 dims as i was originally going to use one of those.
Ray
Old 31st July 2009, 10:09 PM
davidimurray's Avatar
Lookign good mate - although I think you could do with a bigger workshop
Old 31st July 2009, 11:07 PM
RAYLEE29's Avatar
mmm wish my workshop was that small, lol might even be able to have it tidy
Old 1st August 2009, 04:00 PM
Ray
Yeah the MK2 RS2000 bellhousing. I assumed that cos it went onto an escort gearbox OK, it would be fine for the type 9. Sadly its because the clutch arm is more horizontal that the normal bellhousing, pinching on the transmission tunnel sides.
Old 1st August 2009, 06:02 PM
les g les g is offline
Default deezee
have you given a thought to a hydraulic concentric thrust bearing conversion
you could put your engine and box further back then as no arm sticking out at all
cheers les g
congrats on the build so far
