Old 4th August 2009, 10:56 AM
Adam R. Adam R. is offline
Lightbulb BR7 tube question
BR7 should be:
409,92mm like in new fig. 4.2
or
428mm from page 161
and how many mm should be between BR7 and BR10 ?
carbon master
hayens roadster + carbon westfield body
English is not my native language.
If my grammar/spelling is off please correct me, I'm still learning!
Old 4th August 2009, 11:01 AM
not with you there ?
when i cut BR7 i used the dimension from page 161 which is 428mm.
where do you get the dimensions of 409,92mm in fig 4.2 from?
Old 4th August 2009, 11:38 AM
long time ago on the forum was corrected pdf with fig 4.2 and BR7 are 409,92
i don`t have this file but maybe somebody have
carbon master
Old 4th August 2009, 12:17 PM
I cut my BR7 to 428mm as per cutting list on page 161
Looking at figure 4.2 on page 34 the overall dimensions given to the outsides of BR8 & BR9 is given as 478mm
Deduct 50mm for those 2 tubes 478mm - 50mm = 428mm length for tube BR7
The drawing is correct as far as I know, I do not remember any amendments to this part of the chassis.
No idea as to where you get the 409.92mm from !!??( 410mm in the real world )
Old 4th August 2009, 01:26 PM
I don`t remember who make it but I fount it on this forum
photo:
now from the oryginal 4.2 everythink is correct
carbon master
Old 4th August 2009, 01:33 PM
the dimension of 409.92 is the dimension of where BR8 & BR9 meet the rails BR1 & BR2 NOT the position of BR7, which is why i couldn,t understand your original post question.
i would suggest you place BR7 as per the book dimensions stated on page 34, fig 4.2
Old 4th August 2009, 04:24 PM
Exclamation Careful how you go
I don't know where that drawing has sprung up from
The front section of that drawing looks to be narrower than the book one.
You might want to cross-reference those diagonal measuments against the ones shown in fig 4.2 on page 34
If you build your chassis to that layout, I don't fancy your chances of fitting the front suspension brackets
Old 4th August 2009, 05:58 PM
Now I build the same as fig. 4.2
carbon master
