Old 6th August 2009, 10:09 AM
Tilly819 Tilly819 is offline
Default Buttons and switches
Hi all, just want to make sure i dont miss anything. im about to start making the plug and mold for a one peice fibreglass dash and transmition cover and want to incorperate all the switches and dials etc,
Can anyone think of anything iv forgoten.... i have
Speed
Rev Counter
water temp
fuel level
(all part of the Bike Clocks)
Buttons & Switches
On steering collum
side lights, headlights, main beem
indicators left & right, Hazard
Seperate Buttons
horn
engine start
reverse (electric reverse)
rear fog
Lamps
Handbreak lamp
Chears
If anyone can think of anything iv missed that would be great, i have planns for a spectacular dash board
Tilly
Old 6th August 2009, 10:13 AM
how about a "brake fluid test switch" ?
to check that the fluid warning level bulb is working .
Old 6th August 2009, 10:16 AM
ah yes good point, but do you have to have it as a seperate button or can you have it linked to the handbreak light so that if it is low the handbreak light stays on????
Old 6th August 2009, 10:21 AM
Balidey Balidey is offline
Not sure about other cars, but on my Fiat the button is in the top of the reservoir cap. I don't think I have ever used it, so I wouldn't both with a dedicated switch in the dash.
Old 6th August 2009, 10:22 AM
Shift light(s)?
Old 6th August 2009, 10:25 AM
i,m just going from a discussion i had with Spud69, i,m pretty sure that when he went for his SVA he had to have a means of testing the bulb within that circuit from within the cockpit area, it may well work from the handbrake switch, i,m not totally sure but i know Spud has a seperate switch that he can function whilst sitting in the drivers seat.
Old 6th August 2009, 10:27 AM
also, how about a "gear indicator" as you are running a bike engine, they seem popular.
Old 6th August 2009, 10:31 AM
ahh brill, that clears up the break fluid, il fir a seperate light and button to be on the safe side, and as for gear deplay and shift lights they sounds like nice expencive gadgets to have...
Keep em coming people hehehe
Thanks Tilly
Old 6th August 2009, 10:37 AM
Thanks Tilly
i don,t think you need a seperate bulb for the brake fluid lamp, its more a case of testing the bulb that reacts to the handbrake/fluid warning system.
by the sounds of it your dash will be pretty smart, Captain Kirk would be impressed
Old 6th August 2009, 10:42 AM
Ahh right that makes sence chears andy,
Yeh the dash is going to be quite creative sice i have very little space behind the wheel and i carnt put anything big above the tunnel since iv made a high shifter like in a rally car so im going to have to be quite creative as to were i put things but hopfully it wont be to like a 747's flight deck, you might just be able to see the shifter in my progress so far post
tilly
