Old 8th August 2009, 11:28 PM
davidimurray's Avatar
Default Cooling Fan
Anyone used one of the the budget fans from SVC?
http://www.s-v-c.co.uk/prod_fans.html
The price seems fantastic compared to other products and at that size I reckon it would fit nicely inside the front frame. I plan on setting my fan back from the rad so as to avoid the 'dead' spot found when mounting directly to the rad. I will then make up a shroud to help direct the air from the rad to the fan.
Just wondered if anyone had tried this fan and whether it was anyone good?
Old 9th August 2009, 12:55 AM
i am using the fan and shroud off a 1.6 fiat bravo/a cost me nothing and seems to fit nicely once i choped a little bit off the mounting arm.
Old 16th October 2009, 03:21 PM
axle's Avatar
axle axle is offline
The one from a 2.0L Clio Diesel would be another via able option as it doses fit in well with the recommended raditor!!
Regards Axle
