Old 11th August 2009, 09:12 AM
aerosam's Avatar
aerosam aerosam is offline
Default Understanding Polybushes
Hi guys,
I'm expecting the polybushes for my wishbones to arrive today (fingers crossed) and I've just realised I don't really know much about them, as I have never used them before.
So I really have 2 questions:
1. What is the correct method of assembly?
2. Do they need any lubrication, grease/oil?
Thanks!
Sam
Old 11th August 2009, 01:37 PM
fabbyglass
Should be a push fit and should come with some greasey stuff although the insert may prove a tad awkward to get in but no drama really... .honest
Old 11th August 2009, 06:22 PM
aerosam's Avatar
Thanks guys,
the bushes did indeed arrive today and I was able to fit them without much drama at all! The bush halves went in by hand, and I just had to use a G-clamp to press fit the crush tubes.
I have trial fitted the drivers side wishbones with the upright and it all fits and moves really nicely! I'm so chuffed!
One thing, I need to get the correct bolts for the wishbones, I'm thinking M12 x 70?
Old 12th August 2009, 01:02 AM
Default bolts
70mm sounds about right as u would have the bracket width + 2 washers +the thickness of the nut + couple threads out the end of the nut.Just remember u need 8.8 tensile strength bolts,buy BZP(bright zinc plate) also.
Old 20th August 2009, 08:39 AM
Murray Ralls Murray Ralls is offline
Question Poly Bush Source
Please help. Where do you English chappies get your polybushes? I tried sourcing them locally today & they look like costing me more than the rest of the project.
Regards to all.
Old 20th August 2009, 09:06 AM
TSM Locost's Avatar
Default Polybush supplier
http://www.3gecomponents.com all top quality,
lots of Roadster builders use them.
Be Lucky, Mike.
Old 20th August 2009, 09:11 AM
aerosam's Avatar
I got mine from rallydesign
www.raldes.co.uk
i believe they will ship internationally as well.
Old 20th August 2009, 05:19 PM
You could always make your own, UHMWPE is a hard plastic and good for bushes and machines easily,a piece of 19 mm steel bar and off you go.
Old 20th August 2009, 07:16 PM
sam i thought the rally design crush tubes were too short?
Old 21st August 2009, 10:03 PM
Regards to all.
Thanks fellas. 3gecomponents look like the business but airfreight to NZ is a bit horrendous, maybe good old fashioned sea freight will be cheaper. Rally design don't appear to have an e-mail address.
