Old 18th August 2009, 10:36 PM
Default Boring is really boring
Well, HandyAndy is sick of paint, and I'm now sick of small, rotating pieces of metal!!
Boring on the lathe - it takes ages!!!!!!
I'm in the process of making the inserts for the Sierra upright.
Opening out a 19mm drilled hole to 35mm turned ID. It's taking ages, still, at least it's not cold in the garage!!
Just thought I would share my boredom with you all
Sean
Old 18th August 2009, 10:55 PM
Originally Posted by AdrianH View Post
You need an 1 1/4 shank drill to go up from 19 mm then less boring for you to do!
Fun is'nt it
It is worth it in the end just for the satisfaction.
Adrian
I was looking at bigger drill bits, but for 2 items it wasn't worth it. I might well have changed my mind by the end of the second one though.
Yours look very smart, I doubt I will have the collar around the offset though, I don't have a 4 jaw chuck, so will leave the very top flat (although I have seen things turned on an eccentric by putting a coin on one jaw - might try it)
I only have a tiny lathe though, so it takes extra long because I can't take heavy cuts still, means as I take my time there is less chance of a c0ck-up
You're right about it being satisfying though - I did my steering rack extensions and it is a nice feeling when it all works out correctly. I only learned to use the lathe recently, as part of this project.
Sean
Old 18th August 2009, 11:05 PM
what you are doing is "skilled" work, nice one
& i moan about painting??????
Old 18th August 2009, 11:32 PM
sean what lathe is it. i prob have plans to make it cnc if you are any good with electronics?
Old 19th August 2009, 08:01 AM
Ash - it's an Axminster C1, not the micro micro lathe
http://www.axminster.co.uk/product-A...-Mk2-33289.htm
I'm OKish with electronics, but I wouldn't consider converting this one. After the project, I will see how often I use it, and might upgrade to a 9"x20". Now that I would consider CNC for
Sean
Old 19th August 2009, 01:03 PM
davidimurray's Avatar
As a slight aside - I've got a couple of old Denford Starturn CNC lathes kicking round the garage that I keep meaning on selling. I converted one for myself a few years ago to a modern PC controller and it is the one of the best things I ever did. I won't clog up the forum with the details but if anyone is interested in the lathes drop me a PM
Old 19th August 2009, 07:37 PM
geez sean i thought my 14inch bed c2 was a bit small but that thing is tiny. bet you staled it a few times with the 19mm drill bit
hats off to you for managing it. do you have any pictures of the finished item?
Old 19th August 2009, 07:59 PM
I actually started the hole in the drill press, as centrally locating it isn't important to the finished hole.
As for pictures, I'm afraid not. It has just this very minute stopped working No idea why. It has power (green LED is on) but nothing happens. When I put it in an 'at fault' situation (turning main power on when lathe is switched to run) I DO NOT get a fault light.
It has me stumped.
I thought maybe I had burned the motor out, but I can't smell any burning from the motor compartment.
It literally stopped, halfway through a cut. I'm leaving it for a while just in case it was overheating, but I would expect the fault light to come on if it was.
Ho hum, I might soon be in the market for a beefier lathe (every cloud and that)
Sean
Old 19th August 2009, 09:03 PM
have you checked the chuck guard switch they can fail. to be honest it will be a doddle to fix what ever it is as there is virtually nothing to them.
im not sure if the c1 has a thermal cutout but it could be a posability
Old 19th August 2009, 09:47 PM
I never had the chuck guard fitted
I would imagine that if it had died, it would introduce a fault to the system, but I will have to strip it down totally and find out.
It is less than a year old, so I have emailed Axminster to see what they have to say about it.
As for thermal cutout, I left it for 2 hrs then went and tried again - nothing.
Ho hum, I guess the inserts will have to wait. Shame, I had just got the hang of the lathe.
Sean
