Old 31st August 2009, 08:53 PM
Jimmyd Jimmyd is offline
Default Clutch Cable Adjustment
I was making up my pedals today when I realised the Sierra clutch cable doesn't have an adjuster. Has anyone any cunning ideas on how to adjust?
I know older Fords, Escort MK2 etc had an adjuster on the cable and it adjusted down at the bell housing. But I'm not sure of the length.
J
Old 31st August 2009, 09:01 PM
Land Locked's Avatar
I'd possibly look for an old escort or cortina cable
Edit: I've been told by a friend that the tone of the above is a tad sarcastic, that was not my intention at all. I recall that my cortina had an adjustable cable and thought it might be an alternative to the escort which would certainly do the job.
Old 31st August 2009, 10:05 PM
drury318 drury318 is offline
I got a mk1 or mk2 Capri cable from ebay, only about a fiver and really short, it has an adjuster and is perfect length with an eyelet on the pedal end, almost could have been made for the job!
Dennis
Old 31st August 2009, 10:32 PM
Sounds useful drury, I'll have a look on ebay also, I'm at that stage of setting up my pedal box as well.
Old 1st September 2009, 08:27 AM
Part no is MCC1056/QCC1056, mine was from someone like autoclearance or similar on ebay?, it may go straight on, or it may need the plastic housing from the pedal end removing to gain a small amount, it depends how long you have made the tube coming out of the pedal box if you see what I mean, other than that it is made for the job, Cheers, Dennis.
Old 1st September 2009, 04:34 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi,
Firstly Landlocked (I dont know your name) I didnt find your remark at all sarcastic and Im very sarcastic very often so I wouldnt worry if I were you.
secondly thats a good call on the clutch cable guys
thirdly it might well be a good idea for us as a forum to start a thread or pehaps a sticky in wich we can quote part nos and donor cars of the usefull generic parts we find that fit the car well so as to help future builders ???
Ray
Old 1st September 2009, 04:49 PM
I bagged myself one of those this morning
It was funny that this thread turned up, I was looking into this very problem the other day & before I had comitted myself with the pedal box construction
Good idea Ray
Some usefull parts & numbers would be well handy for future reference
Old 1st September 2009, 04:58 PM
gus's Avatar
gus gus is offline
I decided I wanted to use the existing cables, so I came up with my own adjusters.
Basically I welded a nut to the tube coming out of the pedel box. Into this was screwed a bolt with a hole drilled through the middle of it for the cable to pass through. I then welded a tube to the head of the bolt to act as a retainer for the end of the existing cable. I also fitted the bolt with an extra nut to act as a lock nut.
Have a look at the attached pic to see what I mean.
Mark
